FCP hot keys
paul gregory
FCP hot keys
on Sep 2, 2011 at 9:11:10 am
I recently worked on a FCP suite and the user had a custom short cut in play - shift F4 locked all the video tracks with in the time line, shift F5 did the same for the audio. How can I achieve this????
He also had his keyboard set so that you press only + and - to expand the time line (whereas the default setting you have to press cmd + and cmd -
Probably really simple solutions but ive got used to those setting now!
Many thanks.
Jerry Hofmann
Re: FCP hot keys
on Sep 2, 2011 at 1:26:07 pm
You can map any command to any key using the Keyboard editor found in the Tools menu.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
