XML Sequence doesn't import clips in timeline
Greg Norton
on Sep 1, 2011 at 10:10:14 pm
Hi, I need a bit of help with an XML problem...
I'm using XML to get a project from FCP7 into FCP6 on my computer. I've exported an XML of the project as version 4 and then opened it in FCP6 and everything seems to be in order in regards to clips and sequences etc coming in, except for one sequence (my main edit) for which the timeline is totally empty. A number of other sequences open fine except for this main one. The thing that is puzzling me is that in the browser the offending sequence has all the right information in regards to duration, format etc. which matches up with the sequence on the FCP7 project just nothing in the timeline. It has quite a lot of tracks (10V 18A) so I tried making a copy and deleting a number of tracks and then bringing that in as an sequence XML in case that was confusing things but the same problem occurs.
If anybody else has experienced a problem like this i'd appreciate if you could share your solution...thanks
