Final Cut and Compressor Freeze at Output
Neil Redman
on Aug 30, 2011 at 6:44:23 pm
Hi, I am trying to export footage that I have in Prores to H.264. Every time I'm exporting the progress bar goes really quickly to about 7 percent and then it just freezes and the remaining time just keeps getting longer and longer.
I have this problem no matter if I export it straight from Final Cut or if I send it to Compressor first. I have the same problem if I try to encode other footage via compressor it stops everytime it gets to around 7 percent.
Any ideas why this is happening?
I tried as a workaround to encode the prores sequence with adobe media encoder, however afterwards the encoded footage looks a lot darker than it did before.
Rafael Amador
Re: Final Cut and Compressor Freeze at Output
on Aug 30, 2011 at 7:21:28 pm
Hey Neil,
This may be caused by any element or media in your time-line, so render it to try to find out if is any aproblem.
When sending to Compressor to a "Multi-pass H246", the sequence will be rendered THREE times; even if FCs time-line was fully rendered (two times for a Double-pass MPEG-2).
DonĀ“t waist your time. Export a Prores Self-contained and import to Compressor.
© 2018 All Rights Reserved
