Convert 23.98p to 59.95 1080i
Ash Man
on Aug 29, 2011 at 10:25:20 pm
Got a request to convert 23.98 (1080p) footage to 59.95 (1080i) and can't seem to figure this one out. I'd understand telecine-ing it to 29.97 if it was 59.94, but 59.95 seems slightly tricky.
Any suggestions?
Thanks for the help
Shane Ross
Re: Convert 23.98p to 59.95 1080i
on Aug 29, 2011 at 10:31:02 pm
1080i59.94 is 29.97fps. Don't let the number confuse you...I think they do that on purpose. When you see "i" it means INTERLACED, and 2 fields per frame, 59.94 is FIELDS per second...30fps...at 29.97. So you will be converting 23.98 to 29.97.
There is no such thing as 59.95...that was most likely a typo.
Shane
Chris Tompkins
on Aug 29, 2011 at 10:31:56 pm
59.95 1080i refers to fields, it's 60 fields a sec. It's really 29.97 Frames Per Second.
Chris Tompkins
Video Atlanta LLC
Mark Spano
on Aug 31, 2011 at 3:00:35 pm
to the OP: 59.95 is a typo. There is no 59.95. Only 59.94. Proceed as you were...
