P2 Problem
Lincoln Key
P2 Problem
on Aug 28, 2011 at 11:09:17 pm
Hey guys, I am new to the forum. I am also new to p2 workflow. This is my first time ever using it. I moved 4 p2 cards onto an external hard drive. After that, I went a few days later to log and transfer in Final Cut. When I attempt to Import a card I get the message ""P2_001" contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media." And I had to return the camera immediately after done shooting and format the cards, so I have no way of recovering. Can anybody help on how I can convert files to .mov or import to any other program? Also, on P2CMS everything plays back perfect. Thanks in advance
Shane Ross
Re: P2 Problem
on Aug 29, 2011 at 12:35:21 am
Did you copy over the FULL card structure? Here's the proper P2 workflow...
Tapeless Workflow for FCP 7 Tutorial
if this doesn't work, report back. There are other options, but they cost money. Try this first.
© 2018 All Rights Reserved
