using Utlimatte AdvantEdge with Matrox MX02le MAX
Ben Bacharach-White
on Aug 26, 2011 at 8:01:04 pm
When using the Utlimatte AdvantEdge with Matrox MAX compression it goes SUPER SLOW! Since the Matrox MAX is supposed to compress at faster then real time I'm not sure why it's taking 4 hours to compress 30min worth of footage.
Any help would be greatly appreciated!
Shane Ross
Re: using Utlimatte AdvantEdge with Matrox MX02le MAX
on Aug 26, 2011 at 8:15:52 pm
Everything rendered? How are you exporting? The Matrox compresses faster than real time if you use COMPRESSOR and one of the MAX settings...then it knows to utilize the MAX.
Shane
Ben Bacharach-White
on Aug 26, 2011 at 8:43:36 pm
Sorry about that,
Everything is rendered, running it through MAX compression H.264 1280x720 in Compressor from FCP 7
8 core Mac Pro
Quad-Core Intel Xeon
2.4 GHz
Shane Ross
on Aug 26, 2011 at 9:07:08 pm
Rendered, exported out as a QT reference or self contained?
Hmmm...you aren't using a cluster with this are you? You cannot use the CLUSTER and the MAX at the same time. If you use the MAX, you have to submit it to THIS COMPUTER. And is the red light in the Matrox blinking? that's how you know it is working. Not blinking, then it isn't being utilized.
Shane
Ben Bacharach-White
on Aug 29, 2011 at 7:47:11 pm
Found out the answer is exporting to self contained Quicktime first, then throwing that into Compressor.
