Cheap Camcorder for FCP
trevor ambrose
on Aug 26, 2011 at 6:15:02 pm
Hey guys,
I'm looking for suggestions here: What is a good cheap HD 24p camcorder that is compatible with FCP? ($1500 or less)
Trevor Ambrose
editor
imdb: http://www.imdb.com/name/nm0024430/
Chris Tompkins
Re: Cheap Camcorder for FCP
on Aug 26, 2011 at 6:27:32 pm
It's not that a Camcorder is or is not compatible with an editing system.
Some cams shoot to a format that can be edited directly (JVC w/ MOV wrapper) And some cams shoot to a format that needs to be converted b/4 editing.
I would suggest you buy the best AVCHD camcorder you can afford.
Look into the Panny HMC series.
Don't forget:
Extra Battery
Camera bag
UV Filter
SD Cards
Card Reader
Not to mention everything else.
As you shoot to cards your need for Hard Drives will rise as well.
Chris Tompkins
Video Atlanta LLC
