FCP EXPORT. Is taking forever. Any ideas why?
Robert S.  Pugh
on Aug 25, 2011 at 4:10:08 pm
Hi Guys n Gals,
I'm just trying export a 20min video from final cut pro and I don't understand why it's taking so long.
Hardware Overview: Mac Pro, x2 3Ghz Quad-Core Intel Xeon processors, 8GB RAM - 800mhz DDR2
Export: I'm trying to export the video to the following settings (bare in mind all video has been rendered)
File Type: MOV Codec: H.264 Dimensions 1920x1080
Running Time: 18mins 43secs
It's currently telling me its going to be 2 hours for the export am I being impatient or is there a way that I can speed things up? also I don't have any additional software open.. Apart from safari to type this :)
Dave LaRonde
Re: FCP EXPORT. Is taking forever. Any ideas why?
on Aug 25, 2011 at 4:20:34 pm
That sounds about right. Encoding to H.264 takes a long time.
Dave LaRonde
Sr. Promotion Producer
Steve Eisen
on Aug 25, 2011 at 4:25:43 pm
Export a QT Movie from FCP. Drop that file into Compressor and choose an h.264 setting.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Jeff Meyer
on Aug 25, 2011 at 4:31:49 pm
If you set up a Q-Master Virtual Cluster (System Preferences) you can export a Quicktime out of Final Cut using current settings and compress to H.264 through Compressor. You should be able to cut your time in half using this workflow. Keep your current export going of course, but in the future this workflow could save you time. Google "Compressor Virtual Cluster."
The difference is Final Cut Pro is not multi-core aware. When you set up a virtual cluster in Q-Master you are able to tap into the 8 cores your machine has available. Also, because Final Cut Pro isn't multicore aware feel free to use Safari without concerns of slowing down your export.
Robert S.  Pugh
on Aug 25, 2011 at 4:47:31 pm
Thanks for the advice! I really appreciate it I'm going to try both methods suggested on the forum and with a little luck my next export won't be as tedious. Thanks again all for your help
All the Best - Rob
Robert S.  Pugh
on Aug 25, 2011 at 4:41:03 pm
Thank you for your help. really appreciate it. I'm going to try both methods and with a little luck my next export won't be so tedious.
Thanks again - Rob
Steve Eisen
on Aug 26, 2011 at 12:23:34 am
2 products to look into.
1. Elgato turbo.264 HD
2. Matrox Compress HD card or any MXO 2 with Max.
Steve Eisen
Vice President
