ProRes 4444 alpha channel stopped working
Espen Moe
on Aug 25, 2011 at 11:45:05 am
Hi Creative Cow Users, I really hope you can help me.
I encountered a really strange problem with the ProRes 4444 codec.
From yesterday to today the alpha channel in the codec simply stopped working.
No matter which (4444) settings I try to output in, the .mov only shows millions of colors with no alpha.
I have been trying alot of workarounds e.g. exporting to Apple Animation with alpha,
and then using QT7 to convert this to 4444, with the same result.
The exports of the same unaltered AE CS5 project worked perfectly yesterday.
And I haven't made any updates of soft or hardware.
I even tried this:
http://blogs.adobe.com/toddkopriva/2010/05/prores-4444-and-prores-422-in.ht...
Hardware:
MacPro 2x2.93 GHz Quad-core Intel Xeon.
Nvidia GeForce GT 120
BlackMagic DeckLink HD Extreme
Software:
Mac OS X 10.5.8
Adobe Production Premium CS5 (primarily After Effects)
Final Cut Studio 7
A solution or hint will be highly appreciated.
Best regards
Jeremy Garchow
Re: ProRes 4444 alpha channel stopped working
on Aug 25, 2011 at 3:30:06 pm
[Espen Moe] "No matter which (4444) settings I try to output in, the .mov only shows millions of colors with no alpha."
What are you outputting from?
Espen Moe
on Aug 25, 2011 at 7:13:42 pm
I use AfterEffects CS5
Other codecs' alpha channels work fine with output from AE…
E.g. I tried rendering to Apple's Animation codec, with no alpha problem.
Then I used Quicktime 7 player to export this to ProRes(4444).
The result was millions of colors and no alpha.
Unfortunately I can't use other codecs… needs to be ProRes.
And LiveType which the video is to be used with, doesn't support multiple mattes.
So can't use ProRes(422) either.
Jeremy Garchow
on Aug 25, 2011 at 7:16:32 pm
[Espen Moe] "I use AfterEffects CS5"
So in the output module you have chosen RGB + Alpha? Then millions of colors+?
Espen Moe
on Aug 25, 2011 at 10:36:16 pm
exactly
Jeremy Garchow
on Aug 25, 2011 at 10:44:48 pm
In the fcp browser, find the alpha column. If it's not there, make it available by right clicking on the column head and choose show alpha. Try changing from none to black or straight.
Espen Moe
on Aug 29, 2011 at 2:35:46 pm
First I would like to say thanks a lot for helping me out here !
I tried the FCP cheat you said, and it works fine… great trick btw!
But my problem is that it doesn't work in LiveType where I'm making a toolkit for use in FCP … And FCP won't recognize the alpha data through the LiveType files.
I'm going to go through every element in my projects, reinstalling codecs, and so forth.
I'll let you know if I come up with something.
Jeremy Garchow
on Aug 29, 2011 at 3:28:40 pm
[Espen Moe] "But my problem is that it doesn't work in LiveType where I'm making a toolkit for use in FCP … And FCP won't recognize the alpha data through the LiveType files."
Hmm. I have no experience with livetype. Sorry I can't be of much more help there.
Jeremy
