Trouble exporting from FCP to XDCAM PDW-U1
Geir Ove
on Aug 25, 2011 at 7:38:59 am
I'm having trouble using the export to XDCAM function in FCP.
The export goes fine but when I try to mount the XDCAM disc with with XDCAM transfer og play it on a XDCAM deck I get this error message: xdcam Error reading metadata from file (input stream is not good)
It seems that there is something wrong with the metadata file??
I also tried using Episode Pro to convert and just copy the file to the XDCAM deck. I then get the same error message.
I'm using FCP 7.0.3, XDCAM transfer 2.12.0, PDW-U1 deck firmware 2.450
The file that I'm trying to export is a XDCAM IMX50 quicktime wrapped.
Any suggestions any one?
Is there a way to repair the metadata file or XML file on the XDCAM disc?
Geir Ove
Paul Boots
Re: Trouble exporting from FCP to XDCAM PDW-U1
on Sep 6, 2011 at 11:24:22 pm
I'm having the same thing with a XDCamHD 422 clip in 1080/i50 50CBR with 8 audio tracks.
So it's not just the clip format.
Paul Boots
VFX & Post Production, Supervision & Consultancy
http://filmtools.bootsmade.com
Gustavo Seabra
on Sep 25, 2011 at 1:11:39 am
Hi, i'm having the same problem right now. Coul you fix this in anyaway?
Thank you very much if you can share your results.
Gustavo
Geir Ove
on Oct 26, 2011 at 6:13:24 am
I've searched the web for answers to this question about exporting to XDCAM with U1 deck. As I have understood from my readings the only way to play the clip after exporting to XDCAM is by mounting the disc and play it from the computer...
So you can use this workflow for archiving.
Geir Ove
Geir Ove
on Oct 26, 2011 at 8:11:47 am
I've got this export to work!
Don't exactly what made it work but I installed some new updates from Sony and suddenly it worked!
Here's my setup:
Sony XDCAM Transfer v2.1.13.0
MacFAM Driver v2.3.2
XDCAM Drive Software 3.0
Final Cut Pro sequence settings:
General tab:
QuickTime Video Settings, Compressor: XDCAM HD4221080i50
Audio Setting, Rate: 48 kHz, Depth: 24 bit, Config: Descrete Channels
Audio Outputs tab:
Dual Mono
Then I used the Export Sony XDCAM tool.
Geir Ove
Rashid Zahiruddin
on Jul 18, 2013 at 9:06:32 am
I'm having the same problem using the export to XDCAM function in FCP.
After editing on FCP, I export the clip to Sony PDW-U1 via the file>export>Sony XDCAM Browser.
Immediately the Sony XDCAM Browser Exporter window appear with Headers "FILE", "DESTINATION" and "STATUS".
The status shows exporting in %, but once it reaches 100%, it just stay there for a very long time. Nothing happen after that.
I can't eject the disc from PDW-U1. The Finder hang when I want to view the content on the disc.
Shutdown everything, restart the whole process, still stop at 100%.
I even change to few other disc, but its end up the same.
Please help.
Here are the software's I installed for XDCAM.
1. XDCAM Browser V2.1
2. FAM Driver V2.3.2
3. XDCAM Drive Software (VFAM)
I'm using Mac OS X 10.7.5, FCP Version 7.0.3
Rashid Zahiruddin
on Jul 18, 2013 at 2:49:38 pm
The status shows exporting in %, but once it reaches 100%, it just stay there for a very long time. Nothing happen after that. I can't eject the disc from PDW-U1. Finder hang when I want to view the disc content.
Shutdown everything, restart the whole process, still stop at 100%. Change to another disc, also the same.
Please help.
MIke Guidotti
on Feb 9, 2012 at 5:05:05 pm
XDCAM transfer is no longer supported. Use XDCAM Browser instead, all will be well.
Andy Robinson
on Feb 9, 2012 at 7:57:56 pm
For what its worth, I was having the same problem, I upgraded from XDCAM Transfer 2.12 to 2.13 and it fixed the issue.
Kimberly Holmes
on Mar 12, 2012 at 7:05:50 pm
I encountered the same issue. I decided to look at the disc with XDCAM Browser Version 2.0.0.222 [instead of the older XDCAM Tranfer software], and the exported clips look fine with no error messages. The exported clips also played back fine in camera [PDW-F800].
Edward R. Murrow on Television
"This instrument can teach, it can illuminate, yes, and even it can inspire. But it can do so only to the extent that humans are determined to use it to those ends. Otherwise it's nothing but wires and lights in a box."
Rashid Zahiruddin
on Jul 18, 2013 at 2:56:01 pm
Please help.
