FCP7 output to HDCAM SR
Steven Escobar
on Aug 25, 2011 at 4:29:39 am
I am trying to make an output to HDCAM SR and probably going to take it to a facility that has FCP7. My question is there a way to export a QT with 10 audio channels or should I just setup a FCP project with all the channels?
Steven Escobar
G4 1.25MHz Dual MDD
1.25 RAM
IgniterX RT w/component
QT 6.04
OS X.2.8
FCP 4.1
Med
Shane Ross
Re: FCP7 output to HDCAM SR
on Aug 25, 2011 at 5:14:18 am
Here's how you do that:
http://library.creativecow.net/ross_shane/multi-audio/1
Shane
Michael Gissing
on Aug 25, 2011 at 5:15:46 am
You can make a multi channel quicktime. In FCP you need to select for 10 channel output (sequence settings) and patch each channel to its output channel.
Patching is done by right mouse click in the audio track next to the lock icon and selecting the output for that channel.
