Magic Bullet Looks gets pixilated with Final Cut Pro.
Kristian Vestergaard Jensen
on Aug 24, 2011 at 9:23:21 am
Hey everyone,
Im having some problems using Magic Bullet Looks with Final Cut Pro 7. When I apply looks to clips in my timeline the clips gets pixilated. It works fine with After Effects and in stand-alone-mode. So I figured that it has something do to with my settings in FCP.
Can somebody help me?
Best regards
Kristian V. Jensen
Denmark
Ryan Rivard
Re: Magic Bullet Looks gets pixilated with Final Cut Pro.
on Aug 24, 2011 at 2:10:17 pm
Kristian,
I've actually encountered the exact same problem. Have you had any luck figuring out a solution?
I'm also running FCP7 and MBL2.0
Ryan
on Aug 24, 2011 at 2:17:53 pm
Nope.. So I hope there's somebody in here who can help.
Ryan Rivard
on Aug 24, 2011 at 2:36:11 pm
Kristian,
I actually found a solution with a bit of digging. It was in another post. All you need to do is go to Sequence>Settings>General Tab and set the field dominance to "None". That fixed it for me. According to the other post, Red Giant is aware and attempting to fix the problem.
Good Luck!
Ryan
on Aug 24, 2011 at 4:03:13 pm
Thank you so much Ryan.. That fixed it.
Dave LaRonde
on Aug 24, 2011 at 4:00:52 pm
[Kristian Vestergaard Jensen] "...problems using Magic Bullet Looks with Final Cut Pro 7.... the clips gets pixilated.... I figured that it has something do to with my settings in FCP.... Can somebody help me?"
Not without more information!
What's your computer & OS Version? Find it under "About This Mac".
What's the precise version of FCP? Find it under "About Final Cut Pro".
What about the footage in question: codec, resolution & frame rate? Interlaced or progressive?
And which settings in FCP do you believe may be the culprit?
Dave LaRonde
Sr. Promotion Producer
