Stereo Channels Out of Sync in FCP
mark procopio
on Aug 24, 2011 at 3:09:42 am
Please Help -
I have imported an AIF file into FCP. I have not added video and I have rendered the music. When I play it back - the stereo files echo from being out of sync. I have read posts about wavforms and cache and have turned them off and emptied them.
I have also run disk utility, rebooted and still no change.
I don't know what to do.
iMac 3.2 Intel i3 8GB 1333 MHz DDR3 1TB HD FCP Version 6.0.6
Thanks to any that may be able to push me in the right direction.
Michael Gissing
Re: Stereo Channels Out of Sync in FCP
on Aug 24, 2011 at 3:44:47 am
If the audio needed rendering then it isn't the right settings for FCP or your sequence settings are wrong.
FCP works best when files are 16 or 24 bit, 48khz sample rate. FCP sequence should be 48khz 32 bit.
mark procopio
on Aug 24, 2011 at 4:43:02 am
Thanks for the quick reply! I tried those steps, and it still seems as though the left channel is lagging behind the right to cause the echo.
Any other thoughts?
Thanks again in advance
