Problem - Quailty of video clip degraded by FCP
Adam Gil
on Aug 23, 2011 at 8:00:34 am
Hi All,
I need some help with FCP, I am getting married in 2 weeks and am in the process of making a video to play at the wedding.
I have footage's from two different cameras.
One is a Canon XH-A1, its footage is in 1920x1080.
The Other camera is a Sony handycam DCR-DVD650, its footage is 720x480 (29frams per/sec , 9100kbps)
The 1920*1080 clips are all fine.
The problem is that when I open the 720x480 clips with FCP they are very smudgy whenever there is movement (all straight lines seem wobbly).
On the other hand, when I open these clips outside of FCP, with quicktime for example, their quality is great and not smudgy at all.
Please Help ;)
Dave LaRonde
Re: Problem - Quailty of video clip degraded by FCP
on Aug 23, 2011 at 2:33:35 pm
Any time you compare SD to HD, you're going to see big differences in image quality.
HD gives you 5 times as many pixels to get the picture looking good.
Dave LaRonde
Sr. Promotion Producer
Adam Gil
on Aug 23, 2011 at 4:29:39 pm
so IS the answer to my problem, to just change the settings of the sequence to SD ?
when I play the 720*480 with quicktime it look fine... without smadges.
Dave LaRonde
on Aug 23, 2011 at 6:05:29 pm
Work in SD -- 720x480. You'l probably have to do more rendering than you ever thought.
Dave LaRonde
