FCP HD have to rerender text all the time
cynthia madansky
on Aug 22, 2011 at 3:01:46 pm
I am working in FCP HD 6.0
and have a problem with the text layer laid on top of the moving image:
A.
Sometimes the text is fine,
B.
Sometimes in the middle of the sequence,
on the same clip or on a new clip
the red render line appears
C.
Sometimes I can paste a clip with text which has a red render line into a new sequence and it is fine, the red disappears
other times it is not and it just copies into the new sequence with
the red
I am not sure what the reason is for this.
Please let me know the steps i can take to remedy this.
i know it is possible!
thank you very much
Cynthia
Everest Mokaeff
Re: FCP HD have to rerender text all the time
on Aug 22, 2011 at 4:23:09 pm
The reason behind it is cache size. In System Settings in tab Memory & Cache increase Still cache, disk and RAM. Relaunch application.
Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
http://www.mokaeff.com
cynthia madansky
on Aug 24, 2011 at 7:17:34 pm
Thank you Everest.
I will try this tomorrow, What should I increase them to?
a. still cache
b. ram
d. disk
