Compressor Crashes
Roi Turnoy
Compressor Crashes
on Aug 22, 2011 at 11:45:41 am
Hi Guys
One of my clients has a problem with his compressor.
He has FCP Studio 3 installed.
Every time he drags a clip to the compressor - it crashes.
I tried to run Compressor repair, but it didn't help.
Before I try to reinstall the program I would like to know if there another way to fix it.
The clients Mac Specs:
Mac Book Pro (1,1)
1.83 GHz Intel Core Duo
2GB 667MHz DDR2 SDRAM
Mac OS X 10.6.8
Everest Mokaeff
Re: Compressor Crashes
on Aug 22, 2011 at 12:02:07 pm
What clip Compressor crashes on? Format? codec?
Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
http://www.mokaeff.com
Roi Turnoy
on Aug 22, 2011 at 2:13:59 pm
any kind of format - But also Quick Time reference and Self Contained...
Jason Brown
on Aug 22, 2011 at 1:27:11 pm
Digital Rebellion makes a small app called Compressor Repair. I've had similar issues and it's helped fix things up for me.
Roi Turnoy
on Aug 22, 2011 at 2:15:27 pm
As I wrote in the beginning of the post - I already tried it and it didn't help...
Mark Spano
on Aug 22, 2011 at 4:05:43 pm
every time I have any issue with Compressor, this sorts it: open Compressor, go to the Compressor menu and choose Reset Background Processing. Choose Reset and Cancel Jobs. Wait a minute. Then resubmit the job. If there's still an error, it's not the app, it's the source material.
Roi Turnoy
on Aug 22, 2011 at 4:13:39 pm
Hi
It crashes from the first moment he installed the studio...
So I don't think reset will help (and I think I did it as well)...
And about the source material - it crashes with different kind of clips, so it's can't be the source material...
I thought it could be somthing with his mac - it's an old macbook pro (intel version).
Mark Spano
on Aug 22, 2011 at 4:20:11 pm
Then a reinstall of FCS3 is in order. Once that's done, run Software Update and keep running it until there are no more Pro Apps updates left to install.
