Export for Projector NEC VT59- standard projector size
Michelle Orpe
on Aug 21, 2011 at 10:58:24 am
Hi Guys
I am about to export a project I have made consisting of photo's and a motion template. I am putting it onto disc and that disc will be played on a Sony PC to a projector NEC VT59- standard projector size
Can anyone tell me the best settings & codec to export it, I'm worried as I have a Mac that the DVD won't work in a Sony PC
Thank you so much
Michelle
Michelle Orpe
http://www.michelleorpe.com
Rafael Amador
Re: Export for Projector NEC VT59- standard projector size
on Aug 21, 2011 at 12:12:26 pm
Hi Michelle,
That's an SD projector.
Up to Google:
Accepted Video signals
PAL/PAL60/NTSC/SECAM/NTSC4.43/PAL-N & M
[Michelle Orpe] "Can anyone tell me the best settings & codec to export it, I'm worried as I have a Mac that the DVD won't work in a Sony PC"
DVDs are all the same (MPEG-2 video) and they should play in every computer, although some particular computers have problems with some brans of disks.
Make a plain NTSC DVD and try it in a domestic player. If its plays there, your DVD is OK.
You can't do much if some computers reject the disk, then there is a problem with the PC, not with your DVD.
rafael
http://www.nagavideo.com
Michelle Orpe
on Aug 21, 2011 at 1:10:51 pm
Yes, and I am working in PAL, just wondering if I should export in H.264 or DV PAL or Apple Pro-Res or any of the other millions of options :-)
Michelle Orpe
Rafael Amador
on Aug 21, 2011 at 3:15:03 pm
[Michelle Orpe] "Yes, and I am working in PAL, just wondering if I should export in H.264 or DV PAL or Apple Pro-Res or any of the other millions of options :-)"
OK PAL.
You can "Send to Compressor..", or you can export a quality master from FC and compressit with whatever application.
Export from FC with the lower compression you can: Prores better than DV.
H264 is for OK for acquisition or delivery but no when you need process or compress again.
rafael
Michelle Orpe
on Aug 21, 2011 at 8:20:45 pm
Thank you so much, I now think I understand, the DVD is made and it works on my mac, on an old PC I just tried it in and in the TV DVD Player woohoo
Michelle Orpe
