Working with CRAZY weird aspect ratio without constant rendering?
Danny Brothers
on Aug 19, 2011 at 7:38:22 pm
Hi there,
Something similar to this might already be posted but I seriously doubt it.
Received 16:9 footage shot Alexa and RED (the Alexa failed halfway through the day...strange). All RED footage has been transcoded to ProRes4444 and matches exactly the properties of the Alexa footage.
The DP used very old, Russian LOMO anamorphic lenses and (thank god) a frame chart with a circle. When I distort the clip my aspect comes out to something like 3.35:1.
Everything is good so far except that in order to work with that ratio, I'm having to render out every single clip as I go along. Any changes require a re-render.
My sequence settings are as follows:
APPLE PRORES 4444
23.98fps
1920x574 square pixels
My clip settings are as follows:
APPLE PRORES 4444
23.98fps
1920x1080 square pixels
Scale: 100%
Distort/Aspect: -87.23
Hardware:
Mac Pro 4, 1
8-core, 2.26GHz
8Gigs RAM
working off of a firewire 800 shuttle drive (i'm in the field).
I thought keeping the clip size at 100% would eliminate the need for constant rendering. Also, I tried playback settings at safe and unlimited RT, low-quality video playback, etc. I left it at full frame rate always because its a music video and sync is important. Nothing seems to even get me to even low-res playable stuff.
Do I need to copy all the working clips to the internal drive? I hope not, this is a tight-turnaround job and that would present difficulties.
Thank you in advance!
-db
Fred Miller
Re: Working with CRAZY weird aspect ratio without constant rendering?
on Aug 19, 2011 at 8:03:02 pm
Pretty sure that PRORES 4444 may be a bit too fat for RT playback from a FW800 drive. Also any clips that you have applied a distortion setting will probably need to be rendered.
FCP Studio 2
Dual 3Gg Quad Core
4Gg RAM
KONA 2
OS 10.5.8
Danny Brothers
on Aug 19, 2011 at 8:08:11 pm
That's what I'm thinking. Is there any workaround that doesn't involve a transcode or copying the files to a system drive?
Jeremy Garchow
on Aug 19, 2011 at 8:08:46 pm
Anytime you add a motion effect, you are going to need to render.
I would work at a timeline that matches your footage (1920x1080). You can then choose to distort (render) or not. This way, you won't have the weird sequence setting to deal with either.
Jeremy
Danny Brothers
on Aug 19, 2011 at 8:54:03 pm
I was afraid of that - wanted to work with unsqueezed footage. C'est la vie.
Thanks for the comments!
Jeremy Garchow
on Aug 19, 2011 at 8:57:10 pm
i would try it in a normal sized sequence (1920x1080), and then check the distort. It might not be such a bad render, but it will need a render.
Jeremy
Rafael Amador
on Aug 19, 2011 at 9:23:48 pm
[Jeremy Garchow] "i would try it in a normal sized sequence (1920x1080), and then check the distort. It might not be such a bad render, but it will need a render."
I would follow Jeremy's advice,
[Fred Miller] "Pretty sure that PRORES 4444 may be a bit too fat for RT playback from a FW800 drive."
Apple Prores444 is some 330Mbps data rate, while FW-800 supports 800Mbps.
It should be no problem to play one stream in RT.
rafael
http://www.nagavideo.com
