Exporting for a projector
Michelle Orpe
on Aug 19, 2011 at 2:49:59 pm
Hi
I've read a few posts about this but I'm still a bit confused as to what will be best. I have a project that is going to be shown on a projector through a laptop the project consists of:
Pictures at 1024x1509, 1288x1024 etc which I have put motion to
Text
Motion Template 1920x1080
The sequence settings are: 720x576 CCR601/DV Pal (5:4)
I am in England. What should I export this as for this to be shown on the Laptop/projector?
Thanks for helping
Michelle
Michelle Orpe
http://www.michelleorpe.com
Jonan Grobler
Re: Exporting for a projector
on Aug 23, 2011 at 10:06:27 am
Well, it depends on the specs of the projector itself.
Seeing as you're working with HD content though, I would definitely recommend changing the sequence settings to say 1280x720 (HD (960x720) (16:9)). This should be fine for most projectors.
Also, your photograph sizes aren't optimal for the higher 1920x1080 resolution, you would have to zoom them up for that. So stick with 1280x720.
