Batch Increase Volume Of Source Clips?
Eddie Kesler
on Aug 18, 2011 at 5:53:38 pm
I have a couple spot worth of source footage shot on Alexa and the sync audio is very low. Is there a way to increase the volume of all clips in the bin using a shortcut or command? I can of course manually do each one, but the Opt+Com+L only works in the timeline.
Eddie
http://www.jamedit.com
Jeremy Garchow
Re: Batch Increase Volume Of Source Clips?
on Aug 18, 2011 at 6:16:03 pm
You would have to do it in the timeline, then drag them back to the bin.
Or one by one in the viewer.
Jeremy
John Pale
on Aug 19, 2011 at 3:38:04 am
Or Batch Process the source files in Compressor. You will end up with duplicate files (but louder). Then reconnect to the processed files.
