Interlaced or Progressive Motion Graphics in Interlaced Timeline?
Travis Stewart
on Aug 17, 2011 at 2:58:59 pm
I am still getting used to using these forums so maybe I didn't search in the right places, however I would appreciate any advice someone may have for this question:
I am working in a 422 ProRes Interlaced timeline, and am outputting graphics from Motion in the 422 ProRes codec. Progressive I hear is the best way to output, but if it is ending up in an interlaced timeline, should I just be outputting them interlaced?
I'm sure there's a simple answer to this, I just don't want to make any guess work with this. Thank you for any advice you may have.
Dave LaRonde
Re: Interlaced or Progressive Motion Graphics in Interlaced Timeline?
on Aug 17, 2011 at 3:26:55 pm
Take your pick. If you want the smoother motion characteristic of interlaced 29.97, make it interlaced.
If you want a more film-style motion characteristic of progressive, make it progressive.
I mix progressive animations in an otherwise interlaced edit timeline with no problems.
Dave LaRonde
Sr. Promotion Producer
Michael Gissing
on Aug 18, 2011 at 1:38:14 am
Depends on the movement. Roll titles should be interlaced. I usually ask for AE exports to be done with fields if they are going into an interlaced sequence.
Travis Stewart
on Aug 28, 2011 at 1:20:21 am
Thank you for your help, this helps me immensely! Have an amazing day!
