How have Timestamp from AVCHD file import into Final Cut Pro
jb yong
on Aug 15, 2011 at 4:11:03 am
I have sony avchd files that I converted into apple pro res 422 LT using final cut pro File and Transfer.
However the files does not generate time stamp on these file or Start Time.
I have to mix these avchd files in with Canon 7D files which generates timestamp with Canon EOS plugin for final cut.
I would like timestamp so I can sort all these files together by timestamp. Unless there is better way of organizing lots of files.
Shane Ross
Re: How have Timestamp from AVCHD file import into Final Cut Pro
on Aug 15, 2011 at 6:27:43 am
Most AVCHD formats don't record timecode, so FCP doesn't look for it. Each clip starts at 00:00:00:00. Some cameras do record timecode...but for some reason FCP 7 and 6 don't look for it, or don't care about it. CLIPWRAP 2 will transfer it for you though.
Shane
