broadcast safe
Kolbjørn Voll Hjelmerud
broadcast safe
on Aug 14, 2011 at 10:25:51 am
I have some shots hotspots in my sequence, with too bright light, I need to make them broadcast safe, and I know that a yellow exclamation mark indicates a problem with either the luminance or chroma. How do I know which is the problem? and how do I fix it?
Jerry Hofmann
Re: broadcast safe
on Aug 14, 2011 at 2:57:38 pm
Lower the levels of the video until the green checkbox appears. Use the Color Corrector 3-way filter. (slider under the right-most color wheel). If the source is video from a camera, it's unlikely that the Chroma levels are the problem.
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog:
Current DVD:
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
© 2018 All Rights Reserved
