How can this effect be easily replicated?
Larry Watts
on Aug 11, 2011 at 9:20:27 pm
We have a 20 minute video that needs a large number of still photos added to the sequence. I've chosen a simple effect to bring the pict in and keyframed a scale and rotation move followed by a chosen effect to exit the pict.
I want to apply this total effect to each and every photo I've placed on the timeline sequence. How to do this escapes me. I'm working in FCP not motion, mind you. (I'm open to doing this in motion if it is a faster workflow)
FYI, I actually plan on making 4 or more effects to apply and mix them up so it is not so predictable.
Anyone have a solution?
Larry
Neal Broffman
Re: How can this effect be easily replicated?
on Aug 11, 2011 at 9:34:25 pm
Select the first photo to which the effect has already been applied and hit command-c. Then highlight the rest of your stills and hit option-v (paste attributes) and select the motion and other parameters that you want to apply. This assumes that all of your stills are the same size when you prepared them.
Neal Broffman
One Production Place, Atlanta, GA
http://www.oneproductionplace.com
Latest short: "Line of Sight"
http://deyoung.famsf.org/deyoung/exhibitions/marco-breuer-line-sight
Produced for the deYoung Museum in San Francisco
