Workflow recommendation needed
Matt Dufilho
on Aug 10, 2011 at 8:26:56 pm
I would appreciate any critique/advice on my planned workflow for an upcoming project:
Integrating architectural animation with interviews/talking head shots, shot in 720p30.
Animation will be delivered as image sequences from 3DSMax (3DS Max project settings: 720x480 0.9PAR Anamorphic). I will put these trough After Effects and render out ProRes files of same res. Unable to get HD renders from animators due to render times...they have to stay SD.
Delivery: online widescreen video; widescreen DVD
PLANNED WORKFLOW:
Edit interview/talking head segments natively in 720p. Design motion graphics in 720p.
Add animation to 720x480 0.9PAR Anamorphic timeline. Paste edited interview segments. Paste motion graphics.
Anything I could do differently?
Could I ask for anything different resolution from my animator to avoid non-square pixels in my edit?
If nothing else, I appreciate any advice.
-Matt Dufilho
Jerry Hofmann
Re: Workflow recommendation needed
on Aug 10, 2011 at 8:44:19 pm
What's the delivery format to be? A web stream or a DVD or HD broadcast or?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Matt Dufilho
on Aug 10, 2011 at 8:56:08 pm
online widescreen and widescreen DVD
Jerry Hofmann
on Aug 10, 2011 at 9:56:06 pm
You might find then that working in an SD 16:9 sequence may look better in the end because you're not up razzing the SD to HD... try it both ways and then compress to the deliverables with say, just a couple of shots using the SD and HD footage in a short sequence. See if you notice a difference between the two in the end.
Jerry
Current DVD:
