Transferring project from FCP to Avid with no quality loss?
Edward Calabig
on Aug 10, 2011 at 4:02:03 am
Hi I was wondering if there was a way to transfer a project from FCP to Avid with no quality loss? I'm using PluralEyes with FCP and would like to transfer everything to Avid after it's synced since I don't have PE for Avid. Is there a way to do this with no/minimal quality loss?
My workflow so far has been t2i h2.64 footage -> ProRes LT
Steve Eisen
Re: Transferring project from FCP to Avid with no quality loss?
on Aug 10, 2011 at 4:07:00 am
Automatic Duck
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Edward Calabig
on Aug 10, 2011 at 4:13:02 am
Thanks but I guess I should have asked... is there a free way?
Shane Ross
on Aug 10, 2011 at 4:27:58 am
No. The cheapest is Boris AAF. And you cannot convert FULL projects, only sequences.
Shane
John Pale
on Aug 10, 2011 at 4:06:18 pm
Sounds like you are trying to get your synced clips into your Avid (not a sequence).
You can export each as self contained ProRes LT Quicktimes and bring into Avid via AMA.
If you want better performance, transcode on the Avid to a DNX resolution (Avids native HD format).
Make sure you retain a backup, as these synced clips won't exist anywhere else.
