Connecting external computer to iMac using Final Cut
Mark Jackson
on Aug 9, 2011 at 4:19:26 pm
Greetings all:
How do I connect an external computer monitor to my iMac to use as a client Monitor for Final Cut Pro 7?
Any tips for would be greatly appreciated.
Mark D. Jackson
Shane Ross
Re: Connecting external computer to iMac using Final Cut
on Aug 9, 2011 at 7:31:09 pm
You don't. Not unless it is a very specific iMac:
http://support.apple.com/kb/ht3924
Shane
Andrew Evans
on Aug 9, 2011 at 9:21:48 pm
You need a display port adapter to which ever connection your monitor uses (vga, dvi). In final cut: view -> video playback. Or you could use external video, which uses firewire through a dv camera. Hook the camera up to a tv using rca cables.
Andrew Evans
Lake TV
iMac 2.5G Quad 8GB
FCS 3
Dennis Leppell
on Aug 10, 2011 at 6:10:54 pm
I just saw a product announcement that breaks out the thunderbolt port to two HDMI ports....think it was apple branded, so maybe look into that.
