Create choppy "Skype" video effect
David Warren
on Aug 8, 2011 at 8:25:11 pm
So I'm trying to make a video that was shot on a sony EX-1 look like it was actually shot on a crappy skype webcam. Think 15fps, blurry, etc. I've tried dumping a bunch of filters on it in FCP but it's not so great, I used the G Speed plugin to get it to remove every 2 frames, but the audio loses sync.
any suggestions? doesn't HAVE to be just in FCP, could also use after effects etc.
thanks!
Alan Okey
Re: Create choppy "Skype" video effect
on Aug 8, 2011 at 8:47:03 pm
Strobe filter...
Ernie Santella
on Aug 8, 2011 at 8:52:53 pm
If it's not too long a clip, you could also go in a duplicate some frames randomly to give it more of an analog, less exact strobe effect.
Ernie Santella
Santella Productions Inc.
http://www.santellaproductions.com
Dave LaRonde
on Aug 8, 2011 at 9:20:29 pm
[David Warren] "doesn't HAVE to be just in FCP, could also use after effects etc."
After Effects: Posterize Time effect. Alternately, put it in a comp with the lower frame rate, make sure that you preserve the frame rate of the nested comps in AE Preferences, and nest the comp in one at the proper frame rate.
Dave LaRonde
Sr. Promotion Producer
