FCP Frame count
Johan Goodman
FCP Frame count
on Aug 7, 2011 at 9:10:14 pm
Hello all, long time reader, first time poster.
I haven't actually checked this in Avid yet so it may just be a case of ignorant user as opposed to a FCP-specific thing.
1920x1080 25P project.
I mark one second of slug in the viewer (I do this according to the timecode window top right of the viewer - 00:00:01:00, but according tot he timecode window top left of the viewer, in-out is 00:00:01:01)
Insert it at the beginning of timeline.
Select it and hit Cmd-J and the window shows it as Duration: 00:00:01:01
So that's 26 frames, which is incorrect.
If I mark in to out on the slug (go to start of slug clip, move playhead to end of clip - so that the highlight is on the last frame of the clip and not the following frame) the canvas tells me in-out is 00:00:01:01.
The timeline shows 01:00:01:00.
I'm incredibly confused. What frame should my program start on and end of for say a 30-second spot, while still retaining the one second of slug at the start (not for tape playout or anything, I just like to start a timeline with slug).
Michael Gissing
Re: FCP Frame count
on Aug 7, 2011 at 11:45:22 pm
Marking the out frame at 1:00 means the shot goes to the end of the marked frame so you get the frame you put the out marker on. That is why your duration is +1 frame.
This is the same behaviour as most NLEs that I have used and was also the case in the old days of tape editing.
