Best workflow for Droid .3gp files?
brad hebert
on Aug 6, 2011 at 11:21:10 pm
I've been struggling with this for a while. The files from my Motorola Droid are .3gp and supposedly 720x480. If I put those into a 720x480 DV sequence, the video is squished vertically and it takes forever to render. If I use MPEG Streamclip to convert them to DV 720x480, they are squished and the audio is out of sync. What is the best way to get these video files into Final Cut?
It's frustrating that something as popular as a Droid and Final Cut don't easily work together - shouldn't matter that Droid isn't a professional device. I hope iMovie would understand the files, but I don't know or like iMovie. Any help is appreciated.
Jerry Hofmann
Re: Best workflow for Droid .3gp files?
on Aug 8, 2011 at 2:15:19 pm
Sounds like you need to turn on the anamorphic checkbox in the clip's properties, and in the sequence setting. If that fails, check to see the clip's properties by typing cmd+9, and post those properties here.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
