Converting video from Quicktime to Flash for Web
Neil Orman
on Aug 6, 2011 at 10:24:09 pm
I'm having a lot of problems converting a video from Quicktime to Flash (.FLV) to show on a Web site, and I would be very grateful for any advice. I've been trying to use Adobe Media Encoder to do this, and I'm never sure the best settings to put before converting the video. I'd really appreciate it if anyone could recommend the best settings to put within Adobe Media Encoder or resources that tell me how to do this? Or, I also have Compressor and I believe you can accomplish this task through Compressor, although I could be wrong? So if anyone knows better how to do this task through Compressor or some other software that would be great, too.
Thank you very much,
Neil
Joe Barta IV
Re: Converting video from Quicktime to Flash for Web
on Aug 10, 2011 at 2:51:06 pm
For Adobe Media Encoder QuickTime to Flash I've had success with these settings;
Select Format FLV/F4V
In the Export Settings choose the Format tab and select FLV
In the Video tab I Resize Video to 480x720
Frame Rate 30
The rest of the settings are default
Rafael Amador
on Aug 10, 2011 at 4:42:52 pm
Hi Neil,
The setting will depend very much of the stuff you are trying to compress (4x3 or 16x9), and your target picture size, file size and data rate.
rafael
http://www.nagavideo.com
Joe Barta IV
on Aug 11, 2011 at 7:05:25 pm
Correct. The Resize numbers I posted are for a 16x9 source video. You can play with the sizes and cropping in Media Encoder to get the size and look you are targeting.
Bars & Tone
SALUTE!
