reconnect media not working
Roli Rivelino
on Aug 4, 2011 at 12:10:34 pm
I have a project which I moved onto another drive to create space, however when I try and reconnect the media is greyed out. I tried to reconnect to the media's new location and I've moved it backed to its new location, all to no avail.
Any help or suggestions would be greatly appreciated.
Many thanks
http://www.rolirivelino.com/
System
Mac Pro 2.8Gb quad core
8Gb RAM
1x 320Gb 7200 hardrive
1x 1Tb 7200 hardrive
Nvidia Geforce 8800 512mb Graphics card
1x 1Tb external WD 'My Book' eSata
Equipment
Panasonic AG-HVX 200
Firestore FS-100
Jerry Hofmann
Re: reconnect media not working
on Aug 4, 2011 at 4:31:27 pm
Can you import the media? If you can, does it have the same names as the clip names you're attempting to connect to?
Jerry
Roli Rivelino
on Aug 4, 2011 at 9:27:13 pm
Yes I tried re-importing the tapes (it's a dv project) and that still didn't work.
As far as naming's concerned I've given the various sub clips different names, but don't think I changed the source clips.
System
8Gb RAM
Equipment
Firestore FS-100
Jerry Hofmann
on Aug 5, 2011 at 12:49:01 pm
You can't just choose file/import/files, and select those files you've moved? If not, they might be corrupt and you need to recapture from your tapes.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Roli Rivelino
on Aug 5, 2011 at 4:43:07 pm
OK, actually reimport them into the bins you mean? I'll try that and see if it works.
many thanks
System
8Gb RAM
Equipment
Firestore FS-100
