FCP Multiclip Compression
Josh Celli
on Aug 1, 2011 at 7:49:50 pm
Hi there,
I haven't worked with Multiclip editing before, and was wondering what the best way is to go about compressing my footage in order to use all cameras.
I used four cameras. Two shot at 1440X1080i, 29.97fps and had an external microphone. The other two were Flip Ultra HD cameras which I used as drum cameras. These shoot at 720p at 30fps.
My question is, should I compress all to Apple ProRes 422 (HQ) at 1080 or 720? Which should be adjusted to the other? I know that it is generally looked down upon to "blow up" footage to larger than its intended size, but I also don't want to degrade the 1080i footage.
Steve Eisen
Re: FCP Multiclip Compression
on Aug 1, 2011 at 8:10:29 pm
For efficient workflow, transcode all your footage to ProRes LT then edit.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Josh Celli
on Aug 1, 2011 at 8:20:37 pm
Steve,
Thanks so much for the reply. A few questions...
- Will this degrade the quality of my footage noticeably?
- If I recorded external audio and later used PluralEyes to sync everythIng together, will I have issues?
- Is there going to be an issue with Multiclip because of the interlaced vs. progressive deal?
Thanks again.
Steve Eisen
on Aug 1, 2011 at 8:26:18 pm
Do a test from a few short clips.
Steve Eisen
Vice President
