Canon hard drive camera files
Jonny Cates
on Jul 31, 2011 at 10:05:29 pm
Hi!....quick question....
I think I understand the basic hard drive camera workflow now (thanks to Shane Ross) but I'm a little unclear on one simple OS procedure.
When you first back up your original compressed files from a hard drive cam, do you copy the entire hard drive that mounts up on the desktop; or do you open that drive up - and drag all the folders out and copy them?
It would seem these folders would need to be put into another newly created folder to keep them all under one roof, and then re-name. Do you then just import that one folder into FCP?
Just want to make certain if it's the mounted drive I copy, or is it the folders inside that drive.
Thanks so much.....
Jonny Cates
Jerry Hofmann
Re: Canon hard drive camera files
on Jul 31, 2011 at 10:22:34 pm
Open it, select all, and copy.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Jonny Cates
on Jul 31, 2011 at 10:55:37 pm
Thank you Jerry...
Jonny Cates
