Footage Pixelated when brought into FCP
Rob Erobs
on Jul 31, 2011 at 7:08:41 pm
I created an animation in After Effects which was rendered with the Animation codec at 720*480, square pixels with no interlacing.
I imported into FCP the Aspect ratio setting in motion is set to 0 and the sequence settings match the animation. (720*480 Square pixels, no field dominance.)
I can't get it clear. Please help me!
Jerry Hofmann
Re: Footage Pixelated when brought into FCP
on Jul 31, 2011 at 10:19:54 pm
Judge it externally on a video monitor, and also try looking at it at 100%. Does it still look bad?
Might try a different codec. ProRes 4444 carries alpha if you need it.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
