Converting problems
Jose Fuentes
Converting problems
on Jul 30, 2011 at 2:00:02 am
hi everyone, I just finished a project on FCP7 and is playing good on .MOV format. its is a 2GB file so I convert my file to a .MP4 format to make it smaller for upload it to youtube. After conversion, it looks very choppy, even lose sync with audio, the audio is fine, just a video problem. I used ProRes222, and the default settings for to export my project in HD.
Thanks a lot for reading and helping.
Chris Tompkins
Re: Converting problems
on Jul 30, 2011 at 2:06:11 pm
What did you use for creating mp4?
Fully render sequence.
Export using "Current Settings"
Drop file into compression program.
Create "you-tube" optimized file for upload.
Chris Tompkins
Video Atlanta LLC
Jose Fuentes
on Jul 30, 2011 at 6:32:34 pm
Im using wondershare video converter, I made some tests and after converting my video to .mov (smaller file) it played perfect... Any idea why hd mp4 is causing troubles??
