Sequence Settings
Charlie Foster
Sequence Settings
on Jul 29, 2011 at 12:46:27 am
I have made a huge blunder. I have been editing narrative b-roll on one project and interviews on another project. My problem is that the sequence settings on the b-roll differ from that of the interviews. Therefore, copy pasting these clips on the same timeline give me a stretched out picture on my b-roll.
Interview Sequence settings...
Frame Size: 960x720
Aspect Ratio: HD (960x720)
Pixel Aspect Ratio: HD (960x720)
Compressor: DVCPRO HD 720p60
B-Roll Sequence settings...
Frame Size: 1280x720
Aspect Ratio: HDTV 720p (16:9)
Pixel Aspect Ratio: Square
Compressor: Apple ProRes 422
Is there anything I can do to convert my b-roll into my interview sequence settings? I really hope I do not have to cut the sequence all over again. Please help.
Michael Gissing
Re: Sequence Settings
on Jul 29, 2011 at 1:37:40 am
What is correct? Did you shoot 1280 x 720 or 960 x 720? Once you sort that then copy paste will work if you change the distort settings.
Copy one of the main interview clips and then highlight the broll clips and Paste Attributes>distort to all clips. Voila, everything back to normal.
Bret Williams
on Jul 29, 2011 at 3:21:32 am
In either case you'd want to edit in the 1280x720 pro res sequence most likely. Your graphics will benefit greatly in crispness.
© 2018 All Rights Reserved
