VariCam 3700, Cinedeck, green screen, dual stream 444, ProRes 4444 vs Uncompressed 10-bit 444
Graham Hutchins
on Jul 28, 2011 at 7:10:56 pm
Hello all,
I thought I would query the collective mind that is the Cow.
Title sums it up nicely. Apart from being almost 6x as large, is there any reason I should favor uncompressed over ProRes 4444 as my acquisition format for green screen work.
The media on the Cinedeck are two 256 GB 2.5" SSD drives, which gives me a little over 20 mins record time, which could be a bit of a bottleneck on set with a roughly 50 min transfer per card via eSATA.
I'm leaning toward ProRes, but I would appreciate if someone could tell me why that's wrong.
Thoughts?
Thank you for your time.
-Graham
OSX 10.6.8
AE CS5
FC Studio 3
Octo 2.26GB MacPro, 16 GB RAM
Jerry Hofmann
Re: VariCam 3700, Cinedeck, green screen, dual stream 444, ProRes 4444 vs Uncompressed 10-bit 444
on Jul 28, 2011 at 8:04:44 pm
No serious reason to not use ProRes 4444 IMHO. The reason uncompressed might be better is the fact that when a render happens, the computer doesn't have to uncompress the compressed file, add the filter or whatever, then recompress it back to the codec set in the sequence. This results in a no loss render. ProREs is darn close though. Also believe it or not, Uncompressed renders faster... because it doesn't have to un then re compress...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Chris Tompkins
on Jul 28, 2011 at 9:46:00 pm
How you like-in the 3700 you lucky s.o.b.?
nicely.
Chris Tompkins
Video Atlanta LLC
Graham Hutchins
on Jul 28, 2011 at 9:47:37 pm
Sorry to disappoint, but it's a rental.
-Graham
OSX 10.6.8
AE CS5
FC Studio 3
