FCP different gamma between STOP & PLAY buttons
yanni gregoriou
on Jul 27, 2011 at 10:48:53 am
When previewing a clip, there is a major GAMMA DIFFERENCE between play and stop.
Seems to me that the picture in play mode looks the wright one. But when i stop the picture
the picture looks brighter with a lower contrast.
Yanni Gregoriou
Everest Mokaeff
Re: FCP different gamma between STOP & PLAY buttons
on Jul 27, 2011 at 11:43:46 am
It happens when one uses non-optimized media (non standard res or jpeg/tiff/png/h.264 compressor) or media on time-line is in preview mode and requires rendering (green line).
Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
http://www.mokaeff.com
yanni gregoriou
on Jul 27, 2011 at 1:55:02 pm
in my case, it was a QuickTime Uncompressed movie in HD format. So if FCP has that problem, it means that it is impossible to Color Correct any footage.
Everest Mokaeff
on Jul 27, 2011 at 2:07:03 pm
Take a look at sequence settings. Make sure they match the clip and the latter itself is in format compatible with FCP.
yanni gregoriou
on Jul 27, 2011 at 3:20:05 pm
Thank you Everest for your suggestions about sequence settings.
You see, FCP changes the settings by it self and finds itself the most suitable codec.
So either manually or automatic the problem remains unsolved.
Shane Ross
on Jul 27, 2011 at 5:02:12 pm
It's drive speed and FCP lowering the resolution in order to ensure full frame playback. Faster drives help with this sometimes. But having a hardware IO card to a broadcast monitor or HDTV would help too, as the quality there doesn't shift. ONly in the FCP interface will it.
Shane
yanni gregoriou
on Jul 28, 2011 at 7:11:27 pm
Thank you Shane, seems that this is the only solution...
Dave LaRonde
on Jul 27, 2011 at 3:38:16 pm
[yanni gregoriou] "in my case, it was a QuickTime Uncompressed movie in HD format."
Almost always, there is a codec associated with a media clip. You should look for that clip's codec information in the FCP Browser. It might be 8-bit Uncompressed, or 10-bit uncompressed, but it will help diagnose the problem to know its precise identity.
Dave LaRonde
Sr. Promotion Producer
