Would this work ?
Matt Goodfield
Would this work ?
on Jul 25, 2011 at 6:45:24 pm
I am on holiday in Amercia and want to buy this sony camera for use at home within the UK
I realise that I cannot use NTSC 24p in the UK .
When I was looking at the camera I had a play and changed some of the options and there was 2 other options 60i and 60p
In the UK I am going to be using HD video so would this be okay ??
Shane Ross
Re: Would this work ?
on Jul 25, 2011 at 7:22:37 pm
No. That is an NTSC camera. NTSC is 30fps (well, 29.97)...60hz. And for film we do 24fps (or 23.98). PAL is 50hz, or 25fps.
That camera will not shoot a format compatible with your UK standards. You need a PAL camera.
Shane
