Lut Buddy & technicolor cine style crashing FCP
toby Heslop
on Jul 22, 2011 at 11:12:28 am
Trying to use Magic Bullet Lut Buddy within FCP 7.0.3 with the Technicolor cine style Lut.
everything is transcoded to ProRes, and when I try to render with the Lut & Lut Buddy plug in, everything crashes.
WTF, I thought this pipeline was working. FCP just crashes upon initial trying to render.
Tryed to export the LUT and re-import. no luck, checked the Magic Bullet site, no love.
What's a project to do to use HDSLR with Technicolor Stylizes and tapping the LUT via MB Lut Buddy
Any surgestion to fix the issue?
try to reinstall, repair permissions, restart system, no love!
toby Heslop
Re: Lut Buddy & technicolor cine style crashing FCP
on Jul 22, 2011 at 11:16:58 am
Process: Final Cut Pro [986]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.3 (7.0.3)
Build Info: FCPApp-1008261348~8
Code Type: X86 (Native)
Parent Process: launchd [172]
PlugIn Path: /Library/Plug-Ins/FxPlug/LUT Buddy.fxplug/Contents/MacOS/LUT Buddy
PlugIn Identifier: com.RedGiant.lutBuddyFxPlug
PlugIn Version: 1.0 (1.0)
Date/Time: 2011-07-22 21:14:58.303 +1000
OS Version: Mac OS X 10.6.8 (10K540)
Report Version: 6
Interval Since Last Report: 181393 sec
Crashes Since Last Report: 11
Per-App Interval Since Last Report: 235775 sec
Per-App Crashes Since Last Report: 11
Anonymous UUID: 56FB150A-0A02-46DE-A2E1-7D64A283E609
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Ken Pugh
on Jul 22, 2011 at 1:53:56 pm
Doesn't help you - but I'm also using LUT Buddy with ProRes transcoded footage (from Canon 60D) and having no problems. Although it does render 5 times slower than using Colorista or the three-way. It's quite easy to get the look using these tools rather than the LUT anyway so you wont loose much if you decide not to try and get it working.
Best,
Ken.
8 core 10.6.7 FCP 7.0.3
Alex Legrand
on Sep 11, 2011 at 3:42:42 pm
Hi Toby,
Unfortunately, I cannot help you either, but I have the exact same crash than you have.
Did you find where the problem is?
If you did, could you please let me know? This thing just drives me crazy.
Best
Alex
toby Heslop
on Sep 11, 2011 at 9:51:29 pm
I've stopped using it now, Noe I use an s curce in colorista2
Alex Legrand
on Sep 12, 2011 at 7:10:35 am
Thanks for answering.
May I ask you how you do that?
Are you making your own curve, or are you using the technicolor curve in a different plug in?
Best
Alex
toby Heslop
on Sep 12, 2011 at 10:46:40 pm
colorista 2
Scroll down to the Master grade section
Create an S curve with as much punch as you need, use the rest of the plugin to tweak up to your liking
Francis Levy
on Nov 20, 2011 at 9:25:28 am
Hi guys! I was having the exact same problem, it is fixed by downloading the Technicolor fix here:
http://www.technicolor.com/en/hi/cinema/filmmaking/digital-printer-lights/c...
It is a .mga file that you need to import from the LUT buddy instead of the previous faulty .lut file.
Francis Levy
Colima, Mexico
Shachar Langlev
on Oct 15, 2012 at 2:52:11 pm
How do you inport the .mga file to FCP ? I tried unsuccessfully
Panasonic AF100:Canon 7D: contemplating Scarlet ;-)
FCP 7 editor n teacher
Freelancer DP
Director - my last film is at
http://www.wix.com/folkswagon/film
