1440x1080 = 4:3?
Jeshua Horca
1440x1080 = 4:3?
on Jul 21, 2011 at 6:55:33 pm
So, I've got some footage that needs editing. It needs to be in the following format:
"Standard Definition 4x3"
Now, I've done some google-ing and some people say that 1440x1080 is indeed 4:3 but it sure doesn't look like that to me. I tried putting my FCE's Sequence Preset to 1920x1080 and then my footage then becomes "squished" and looks more like the correct aspect ratio. So I'm a little confused.
Is 1440x1080 an acceptable 4:3 aspect ratio?
Shane Ross
Re: 1440x1080 = 4:3?
on Jul 21, 2011 at 7:10:13 pm
1440x1080 is anamorphic HD. It is 4:3, but stretches out to 16:9 in editing applications. It is called THIN RASTER, as opposed to FULL RASTER that is 1920x1080.
But it isn't SD. SD is 720x486. DV is 720x480.
Shane
Jeshua Horca
on Jul 21, 2011 at 7:32:33 pm
Thanks, Shane.
I can't find an SD preset in FCE. There is a "DV NTSC 48 khz" but I think that is 720x480. Is there any way to get SD in FCE?
Shane Ross
on Jul 21, 2011 at 7:37:01 pm
FInal Cut Express works with DV and HDV...and a couple tapeless formats. The only SD format it works with is DV.
Shane
