Created 2-DVD's worth without respecting Title-Safe Boundaries!
Evan Heckert
on Jul 20, 2011 at 10:26:31 pm
Guys, I've gone and done it. I'm so used to editing for the web, that I spent two months editing a 2-DVD series without regard to title-safe areas. Now the edges of the video are off throughout the entire thing.
The second issue is regarding the aspect ratio, etc. It looks fine on the widescreen TVs, but when I put it on the 27" CRT tv, it stretches the height to fill the screen there, too.
Is there a quick way to fix either of those issues? Many thanks!!
-Evan
Steve Eisen
Re: Created 2-DVD's worth without respecting Title-Safe Boundaries!
on Jul 20, 2011 at 10:49:30 pm
Sorry there is no one click fix.. The quick fix is to redo the tiles so they are within title safe. FCP, Live Type and Motion have safe title guides.
To fix aspect ratio problem on crt set tv to normal mode not widescreen.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Shane Ross
on Jul 20, 2011 at 10:52:15 pm
Quick fix to make things TITLE SAFE? Nope...you have to turn on your SAFE GUIDES and fix all of that manually.
Not sure what the cause of ISSUE 2 is...
Shane
Chris Borjis
on Jul 20, 2011 at 11:57:14 pm
maybe its anamorphic but not flagged as such. (the crt problem)
Andrew Rendell
on Jul 21, 2011 at 8:59:06 am
+1 (to Chris)
Older 4:3 CRTs may not not even recognize the anamorphic flag, so either it would be a manual switch or you'd need a letterboxed version for it to show it right.
Chris Tompkins
on Jul 21, 2011 at 2:40:08 pm
Prob#2:
How is it flagged in your DVD authoring program?
That will tell it to play letterboxed on a 4x3 screen.
Chris Tompkins
Video Atlanta LLC
