How did my captured video turn out 28.36 FPS?
Dan Spezz
on Jul 15, 2011 at 2:36:39 am
I captured some SD video off of a consumer camcorder for a friend and passed along .the mov files. It turns out that the FPS is 28.36. This appears to be a strange and unusual rate for video. I'm trying to figure out why or how this happened. Can anybody shed some light on this?
FORMAT
DV, 720 x 480 (853 x 480), Millions
16-bit Integer (Little Endian), Mono, 48.000 kHz
FPS
28.36
Data Rate
30.30 Mbit/s
Current size
853 x 480 pixels (Actual)
Dave LaRonde
Re: How did my captured video turn out 28.36 FPS?
on Jul 15, 2011 at 1:24:22 pm
Don't rely on the Quicktime viewer for accurate information. Bring the clips into FCP and look at the information you find in the Browser.
Dave LaRonde
Sr. Promotion Producer
Mikko Löppönen
on Jul 16, 2011 at 1:55:14 am
That is because FCP's capture system SUCKS and if it drops frames it will just give a wrong fps file. So it has dropped frames and therefore displays all wonky.
