23.98 Panasonic footage device control
Kim McTaggart
on Jul 14, 2011 at 3:19:23 am
I am loading some 23.98 footage via HDSDI and rs422 into a 1080p 23.98 Prores project using the 1400 deck set at 23.98. It comes in looking fine, no duplicate frames - but the TC in FCP is in 29.97, with skipping numbers. I was using the panasonic VFR 59.97 device control. I tested with a reconform and sure enough, it did not come in frame accurate. I then switched to Sony 23.98 device control and all the clips came in frame accurate, and a reconform worked great. Is this the norm? Why no 23.98 device control for Panasonic or am I missing something? And will I be OK using the Sony protocal - all seems fine!
And am I correct using a 1080p VFR 23.98 project or should I be using 1080 psf 23.98? I am going to cross-post into the Panasonic forum as well.
Thank you,
Kim
Dave LaRonde
Re: 23.98 Panasonic footage device control
on Jul 14, 2011 at 6:06:21 pm
Because your footage is 1080, it is indeed 29.97 if you didn't remove the pulldown. You may be able to do a Reverse Telecine to remove the pulldown and get to the proper frame rate.
Dave LaRonde
Sr. Promotion Producer
