Exporting .mov file
Jim Geis
Exporting .mov file
on Jul 14, 2011 at 2:36:03 am
I recently got a film accepted to be screened at a film festival!!!
They want it in a certain format to compile on a blu-ray. I want to verify my approach.
thanks in advance!
J
720p .MOV format Quick-Time File (check, I'm using "HD 1280 x 720 16:9)
Non-letterboxed (leave "Preserve aspect ratio UNCHECKED, correct)
Non-interlaced ??(Check Deinterlace Source Video??)
Embedded captions (no separate caption file) or subtitles (if any) (N/A)
Audio levels normalized to -12dB (? I have no idea?)
Everest Mokaeff
Re: Exporting .mov file
on Jul 14, 2011 at 10:18:48 am
What is your question? Unlike DVD Blu Ray is very versatile format capable of dealing with wide range of frame rates, resolutions and bit rates. Mov. is not compatible with Blu Ray format unless your film festival explicitly specify so. For Blu Ray you encode in MPEG-2 or H.264.
Audio level normalized means that your sound should be consistent at the level of -12 dB throughout the clip.
Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
http://www.mokaeff.com
