Problem when switching from MOV to MP4 and viceversa
Gorka Maiztegi
on Jul 12, 2011 at 6:38:50 pm
I'm trying to make a video with two different cameras. Both of them use the H.264 codec and same resolution (1080i) but different container: one is MOV and the other is MP4.
The problem is that when I add cuts in the sequence and play it, it will either show a grey screen on all the MOVs or all the MP4 depending on what I edited last.
I'm using Final Cut Pro 7.0.3
Everest Mokaeff
Re: Problem when switching from MOV to MP4 and viceversa
on Jul 12, 2011 at 6:42:17 pm
Convert all footage regardless of container to ProRes and edit it. H.264 for delivery only.
Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
http://www.mokaeff.com
Shane Ross
on Jul 12, 2011 at 6:41:50 pm
COnvert both to ProRes. H.264 is not an editing codec.
Shane
Gorka Maiztegi
on Jul 12, 2011 at 8:24:52 pm
That worked perfectly. Thank you!
BTW, Which ProRes settings would be better to use?
Shane Ross
on Jul 12, 2011 at 9:56:33 pm
Plain old ProRes 422...or even LT.
Shane
