Moving Information from one sequence to a different sequence
Jeff Combers
on Jul 8, 2011 at 10:48:51 pm
I'm currently using final cut 5....
I have a project where i edited a HDV in a SD 16:9 sequence. My question is: is there anyway to transfer the information from the SD sequence to the HDV sequence? Without having to re-edit the whole project. it was captured in HDV and i was using it for a DVD so I had to down convert. Unfortunately, it was delivered captured otherwise I would have used the AJA KONA card. Now i have to drop it to tape in HDV, but can't seem to figure out how to go about it. Thanks in advance. Hope I explained this well enough :)
-Jeff
Chris Borjis
Re: Moving Information from one sequence to a different sequence
on Jul 8, 2011 at 11:32:48 pm
make a new hdv sequence that precisely matches that hdv footage in every way (size & frame rate)
select all the hdv footage in the sequence, copy it to the new one.
if it doesn't fill the screen then select it all, right click and remove attributes (motion) this should unscale it.
Steve Eisen
on Jul 9, 2011 at 12:22:14 am
And if the footage does match the sequence, you should not have to render.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Jeff Combers
on Jul 9, 2011 at 6:15:26 am
Sweet!! thanks again, worked like a charm. I knew it was something easy like that, but wasn't able to figure it out. Thank You!! :)
