Where is the boris window?
Francesco Biagini
on Jul 8, 2011 at 7:28:32 pm
Hi all
I am trying to make a crawling title, and when I open in the viewer the boris title crawl clip from the timeline and click on the "click for option" the window where you are supposed to write and format the text doesn't appear.
Even worse the interface doesn t allow you to click anywhere as if the window was open but I can t find it anywhere!
I can even paste text in it, close and save it by hitting ⌘W, but the actual window is no way to be found.
I searched on the forum and some old posts had the same problem (from final cut 4) but all the suggestions I found didn t work ( trash pref, mirror desktop, arrange window standard)
I am kind of puzzled also because if I open the Boris Title 3D the window appears normally!!
Did anyone experienced something like this?
Any help much appreciated
Patrice Freymond
Re: Where is the boris window?
on Jul 8, 2011 at 8:16:03 pm
Have you tried trashing your prefs?
© 2018 All Rights Reserved
