Gopro v Sony Importing problem to do with fps I think?
Michelle Orpe
on Jul 7, 2011 at 2:00:49 pm
Hi
I have set my easy set up to Apple Intermediate Codec, 1080i and it captures the HDV footage from my 1080i Sony V1E now. But now it is only letting me import 3 of 5 video settings from my gopro. It lets me import all the 25fps options:
r2 16:9 HD Video 720p (1280x720) PAL 25fps
r4 4:3 Tallest HD Video 960p (1280x960) PAL 25fps
r5 16:9 Full HD 1080p (1920x1080) PAL 25fps
but when I try and import any video from these two settings it says:
r1 16:9 wide angle SD WVGA (848x480) PAL 50fps
r3 16:9 widest HD video 720p 1280x960) PAL 50fps
Error, 1 file(s) recognised, 0 access denies, 1 unknown...and doesn't let me import it
What am I doing wrong?
Michelle Orpe
http://www.michelleorpe.com
Neal Broffman
Re: Gopro v Sony Importing problem to do with fps I think?
on Jul 7, 2011 at 2:19:46 pm
GoPro video is h.264 which is difficult for FCP to edit as it is an end user format. Use Compressor to convert the clips to Pro Res and then edit with those.
Neal Broffman
One Production Place, Atlanta, GA
http://www.oneproductionplace.com
Latest short: "Line of Sight"
http://deyoung.famsf.org/deyoung/exhibitions/marco-breuer-line-sight
Produced for the deYoung Museum in San Francisco
Noah Kadner
on Jul 7, 2011 at 4:57:43 pm
You can also use MPEG Streamclip or QuickTime Player 7. Though Compressor is nicest because you can quickly set up a droplet or a watch folder to do the work.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and GoPro HD Hero.
Michelle Orpe
on Jul 7, 2011 at 6:19:45 pm
Hi Noah
So lets say I am using the setting r5 on my gopro which is the 16:9 Full HD (1920x1080) 1080p 25fps when I drop it into Mpeg Streamclip (or compressor) do I choose:
Apple Prores 422
Apple prores 422 (HQ)
Apple prores proxy
Apple prores (LT)
and do I choose whichever resolution matches the original footage, so in this case 1920x1080 (unscaled)
then when it is done and it is imported into FCP, I also have my V1E footage which is in 1440x1080 at 25fps, so what do I do now, do I convert my V1E footage to the apple prores as well (and which one) and what do I select the resolution at for the V1E stuff because there is no choice for 1440x1080 so do I still pick 1920x1080??
Thanks Noah, really appreciate your help
Michelle Orpe
Michelle Orpe
on Jul 7, 2011 at 6:21:29 pm
actually the gopro footage is at 29fps, does this make a difference as well and if so what should I do about that?
Michelle Orpe
Noah Kadner
on Jul 7, 2011 at 8:47:35 pm
I'd suggest 29.97/1920x1080- ProRes (just that- not HQ or Proxy).
Noah
